Encore lower fireback gasket?
whoppr Posted By whoppr, Aug 6, 2013 at 9:56 PM
Thread Status:
  1. whoppr
    whoppr
    Member 2.
    NULL
    Jan 25, 2013
    14
    0
    Hi...
    I have a Vermont Castings Encore 2550. I am in the process of replacing the catalytic and noticed that the gasket for the lower fireback is in rough shape. I know this gasket is 5/16" fiberglass gasket. Does anyone know any other details I may need to replace this? density? brands that may be good? round?
    Thanks in advance
    Werner
  2. jharkin
    jharkin
    Minister of Fire 2.
    NULL
    Oct 21, 2009
    3,789
    1,268
    Loc:
    Holliston, MA USA
    I cant give you any advice on brands but I just bought some generic grey 5/16 rope gasket at the local stove shop to do mine a couple years ago. They have the different sizes on reels and just cut to length, no brand labels. It worked fine.
  3. Defiant
    Defiant
    Vermont Castings Geek 2.
    NULL
    Dec 5, 2007
    2,122
    1,448
    Loc:
    Old Lyme CT
    whoppr,
    It is best to use a low/medium density 5/16" rope gasket (Rutland has decent quality), it will take approx. 4'. Make sure you clean out the channel that the fireback sits in, this will make it easier to put the parts back together especially the throat hood.:cool:
  4. whoppr
    whoppr
    Member 2.
    NULL
    Jan 25, 2013
    14
    0
    Thanks to you both. To clean out channels, although not recommended I usually use a dremel with a wire brush or sanding tip. Seems to work well and hopefully I will have the same luck as there appears to be quite a bit of cement.
    Thank you again
  5. jharkin
    jharkin
    Minister of Fire 2.
    NULL
    Oct 21, 2009
    3,789
    1,268
    Loc:
    Holliston, MA USA
    I do the same, quick and easy. Would take all day with a chisel.
    Defiant likes this.
Thread Status:
