Hi all. First, like a lot of first posts I see here, I'd like to thank everyone for the information they have made available, I've learned a lot lurking and probably won't burn the house down 'now' due to not knowing.
My question has to do with the Englander 13 insert hearth requirements. I see the freestanding 13nc has an R2 hearth spec clearly spelled out, but the 13nci has "Do not install this stove on a hearth that is constructed of wood framework that is covered
by brick or stone and do not install this unit in a zero (0) clearance fireplace" listed. Page 19 has hearth protection in front and on sides of insert noted as R 0.5 which seems to contradict the severity of the previous statement. I also noticed last night in a thread 'tickbitty' saying the insert needs to be on a 6" raised hearth after speaking to Englander which I can't find in the online manual. https://www.hearth.com/econtent/index.php/forums/viewthread/46618/
I have an exterior masonry fireplace, but the hearth is brick laid on a piece of plywood over a crawlspace. I was planning on upgrading the hearth anyway because I see some black char marks on the wood under the house around the hearth. I have a sheet of micore and was going to use one or two air spaces.
My concern is that the insert is putting out a greater amount of heat downward than the leg model since its laying on the hearth. Anyone have any info on this model from installing it.
