englander 25 pdvp settings...who else has one?
joelswork
86
central TN
Anyone out there with a pdvp that's running good? Mine is a 2000 model with the digital control board....need some settings to base at. Does this model even get effected by the lower settingsat higher burn rates? Errrrrr
I think prior to the 2004 models the lower settings affect only the #1 and #2 heat range. After 2004 they affect the upper heat ranges too but you`d best call Englander to verify your stove and date of manufacture.
I sent Mike a pm cause that other posts kind day Leaves out if it is possibly a new board. The other settings seem to be effecting the burn, so I am suspicious.
It is specked out to produce 8-58,000 brush, so far, I can vouch for the 8k.
