I have a 2003 englander 25 pvd. I live in a 600 sq ft mobile home. My trailer is way to hot. I have to turn it off to keep us from opening the door to cool down. 1 bag in 6 hours. I have tried setting the feed rate to 1 and blower to 1. I have tried setting the factory settings to 1 2 1 and still the same result. occationally i have seen a small pellet feed but directly after that its all high fire from their. Pellets feed like the settings are are 9. I did a control panel reboot by turning the stove off then on and holding the 3 bottom buttons. reset the stove to lff 6 lba 4 and aot 1. After reset i fired the stove up, it feed so many pellets it was hitting the glass and a flame that completely covered the glass. could not see the back of the firebox.
I have not attempted any repairs on this unit. I have however made repairs to a quad classic. I did notice just after the last time i fired this up, that the lower auger appears to be forward more into the firebox area. Maybe i never noticed it before. Not sure. does this auger have a set screw that holds it to the motor shaft....not sure what to do. this problem was a gradual process till today with the fire from hell.
