    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. dies9 Member
    belmont nh
    Ive had my stove for 3 years and cant say enough good about it. However the last three fires i have had have been weak. Same wood i have been burning. It seems like the secondary air is block some how. Can someone tell me exactly where the stove gets its secondary air from. And is it possible to be blocked in anyway. Thanks guys/gals
    #1
    Helpful Sponsor Ads!
  2. EatenByLimestone Minister of Fire
    When this happens to me I generally clean the ashes away from the front of the stove. I nearly pulled 6 gallons of ashes out last time this happened after a cold snap.
    Mat
  3. chvymn99 Minister of Fire
    Kansas
    Have you cleaned your flue pipe lately? Have you pulled your tubes and board down to clean?
  4. pen Super Moderator
    N.E. Penna
    The secondary air enters the stove by a rectangular opening found above the large circular opening at the back of the stove.
    However, I agree with checking the chimney. A partially blocked cap will really turn a stove into a slug.
    pen
  5. dies9 Member
    belmont nh
    chimney and pipe was cleaned 2 weeks ago. boards and rails were cleaned also. It seemed to happen right after this warm snap we had in new england. im burning it down now to clean the firebox out.
  6. BrotherBart He Who Moderates
    Northern Virginia
    Warm weather will wreck chimney draft most every time. Most noticeable over 50 degrees.
    StihlHead likes this.
  7. blades Minister of Fire
    WI, Milw
    Pull your tubes and run a wire brush through them as well as the out side. The little orifaces due get plugged up eventually. Warm weather and poor draft go together as was stated before.
  8. dies9 Member
    belmont nh
    i understand warm weather kills draft. However its 15 degrees now. the stove seems different all of a sudden. Im going to give it a good cleaning.
  9. StihlHead Minister of Fire
    PNW Cascades
    Yah, anything over 45 deg F. here and I have a hard time starting a fire. The draft goes to crap.
    At 15 deg F and the draw should be terrific though. Check for creosote buildup on and just below the cap. I had a good buildup just below the cap after a cold snap here in January. The stove pipe was clear up to the top 3 inches, where a thin cone of creosote had formed choking the pipe down to about 2 inches just below the cap. It was weird, like a layer of a hornets nest. Thin as could be, one scrape with a screwdriver and it fell down into the firebox.
