I am a newbie to this forum. I am amazed at all the information that is available for wood/corn/pellet users. I am hoping that someone can give me the inside information for tweeking my burn on my newly installed 10-CDV Englander Corn/Pellet Stove. My problem is that this required information did not come with the unit nor is it in the owners manual.
Issue - My stove works fine when I use wood pellets with the stove set on the pellet program. It will burn on the lowest heat setting of 1 with out any problems. When I burn corn the stove will go out after the initial start-up phase where the stove is pre-programed to run at level 5. With the stove set at level one after the start up phase the corn feed rate is to low to keep the burn pot going.
Any help would be appreciated
