Enviro Boston 1700 Blower Motor Not Working.
MP-In-The-Wind
2
Franklin, MA
Hi All... the blower motor has stopped working....I was moving it to the 'on' position and heard a click when I moved it to the 'run' position. Any thoughts? No circuit was blown in the house fuse panel. Is there an internal fuse somewhere in the stove? Is this a known issue? BTW: stove is about 4 years old.
Thanks.
MP-In-The-Wind
Could be a failed switch or loose wiring. Check all connections.
If jiggling the wires worked, that is a sure sign there is an intermittent connection. This can overheat and cause a fire. Check it out a bit closer.
