    Hearthstone Soapstone and Cast-Iron stoves( Wood, Gas or Pellet Stoves and Inserts)
For Sale Enviro EF-3 Wood Pellet Stove Bay View - 40,000 BTUs $1295.00
Post in 'Articles for Sale/ Wanted, etc.' started by Don2222, Jun 6, 2014.
  1. Don2222
    Don2222 Minister of Fire
    Feb 1, 2010
    7,154
    Loc:
    Salem NH
    Enviro EF-3 Wood Pellet Stove Bay View - 40,000 BTUs Large 55lb Hopper.
    This stove is in great shape, very clean inside and out with a new steel fire brick backing.
    This stove now has a brand new High Quality Gleason-Avery Auger motor, Brand new Enviro Auger and upgraded Nylatron Auger Bearing and EndPlate. Nylatron keeps the auger turning freely so the auger motor lasts much longer!
    300 watt ignitor automatically fires stove in 5-7 mins!
    Proffesionall cleaned and serviced, this is ready to go.
    Call Don - 603-553-7402 $1295.00 See pics below:
    Brand new this stove is $3495.00 delivered and installed -- see link below.
    http://www.masterspelletstoves.com/productdetails/EF3BI.php
    Manufacturer's Dexcription and specs
    The Enviro EF3 pellet stove is the slightly bigger brother of the EF2 with a more powerful igniter and greater heat output through a double row heat exchanger.
    The bay window design provides a good view of the fire..
    First produced in 1991, the Enviro EF3 is good value and has stood the test of time.
    This stove is simple and easy to maintain. It has a long burn time on the low heat setting.
    Heating area 1,800 sq.ft.
    Max. Heat Output 40,000btu.
    Automatic Ignition Yes
    Manual Ignition If needed
    Hopper Capacity 55lbs.
    Burn time Over 55 hrs.
    Fuel Type Standard or premium grade wood pellets
    Glass Air Wash No
    Built in Blower Yes
    Convection Blower Capacity 160cfm.
    Thermostat Compatible No
    E.P.A. Approved Yes
    Emissions 1.96 gr./hr.
    Efficiency 78%
    Dimensions
    Height 30.5 in.
    Width 22 in.
    Depth 24 in.
    Weight 240lbs.
    Window Size 19 in. by 8 in.
    Flue Vent Size 3 in.
    Top Vent No
    Rear Vent Yes
    Rear Vent Height 16.4 in.
    Battery Backup No See Stove Sentry
    Surge Protector Recommended
    Colours Black
    Exhaust Temperature Sensor Yes
    Low Draft Shutdown Yes
    Construction Type Fabricated steel
    Automatic Shutdown and Re-ignition No
    Helpful Sponsor Ads!
