Enviro Mini A and thermostat issue?
OregonCoast64 Posted By OregonCoast64, Oct 4, 2013 at 12:40 AM
Thread Status:
  1. OregonCoast64
    OregonCoast64
    New Member 2.
    NULL
    Oct 4, 2013
    2
    0
    I recently bought a Enviro Mini A pellet stove and it came with no thermostat. I bought a
    LUX ATX1500E PROGRAMMABLE THERMOSTAT and after hooking the wires to pellet stove, a white and red one 18x2 to terminals that say red and red instead of white and red? I proceeded to hook the red wire to RH and white to w on thermostat with no luck? Also there is a pin on this particular thermostat you can change plastic pin to gas or electric,does it matter on pellet stove? I apologize for all the questions first time purchasing a pellet stove.
    thanks,
    Carl
  2. stoveguy13
    stoveguy13
    Minister of Fire 2.
    NULL
    Dec 15, 2006
    984
    27
    Loc:
    CT
    I would put it on gas and make sure it is on RH and W1 .what setting do you have the mini on? the lux says it works on millivoltage and that is what you need.
  3. DBCOOPER
    DBCOOPER
    Feeling the Heat 2.
    NULL
    Jan 23, 2010
    495
    98
    Loc:
    Stowe, Pa
    Gas or electric doesn't matter. Thats for how the fan is controlled on a gas or electric furnace.Doesn't matter for a pellet stove.
  4. imacman
    imacman
    Guest 2.
    NULL
    HUH?
    There are only 2 terminals on the Mini for the stat connection. They go to the W & RH connections on the stat.
    Set the stat for heat, set the stove to "auto/off" or "High/Low", push the "on" button on the stove, and increase the temp setting on the stat until it "clicks" and the stove should start up.
  5. OregonCoast64
    OregonCoast64
    New Member 2.
    NULL
    Oct 4, 2013
    2
    0
    Thanks folks for the help and sorry about the confusion too. As i stated first time owning a pellet stove, but got it figured out.
  6. imacman
    imacman
    Guest 2.
    NULL
    Sounds good.....now, we need to see pics of the stove, or we won't believe you really have one. ==c
Thread Status:
