Etched Wood Stove Glass
Post in 'The Hearth Room - Wood Stoves and Fireplaces' started by REDTAIL, Feb 1, 2012.
  1. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    I've got a SCAN 60 with the big front glass in the door. It develops a semi-permanent grayish/whiteish smoke film
    no matter what kind of wood I burn. I've used SpeedyWhite to get the black soot off, but this film is more of a
    permanent type of thing; SpeedyWhite, 3 different grits of rubbing compound, simple green, CLR, Rutland, oven cleaner will not get it off.
    Has anyone solved this problem?
    Helpful Sponsor Ads!
  2. corey21
    corey21
    Expand Collapse
    Oct 28, 2010
    2,242
    292
    Loc:
    Soutwest VA
    I use paper towel dipped in hot water then dipped in wood ash. Then i take clean damp paper towel and go over it after i finish.
    Collapse Signature Expand Signature
  3. firefighterjake
    firefighterjake
    Expand Collapse
    Jul 22, 2008
    16,946
    3,465
    Loc:
    Unity/Bangor, Maine
    H2O-dampened sheet of newspaper . . . that is all.
    Welcome to the forum by the way Redtail.
  4. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    I've heard of folks doing that. But, if Speedy White won't make a dent in this stuff, I doubt that this method will work in my
    case... However, I'll try it tomorrow. Note, this isn't the black soot that comes off fairly easily; this is more of a permanent
    grayish film that blocks visibility through the glass. It may be particular to this stove model, I'm not sure...
  5. Adios Pantalones
    Adios Pantalones
    Expand Collapse
    May 20, 2008
    6,585
    1,421
    Loc:
    S.NH- Mass's smoking section
    paper towel, water, that's it.
    edit: a permanent white film- either that's something about how the glass was made, or maybe it's scratched/etched? My white film comes off easy peasey
  6. corey21
    corey21
    Expand Collapse
    Oct 28, 2010
    2,242
    292
    Loc:
    Soutwest VA
    I agree the glass may be made like that.
  7. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Thanks Jake! It's a great forum. I know, for sure, that wet newspaper won't work for me. This is a
    baked on grayish film, not ordinary black soot. Although, I do get a little soot normally too. But, SpeedyWhite
    does a great job on the soot. Lots of other cleaners and probably wet newspaper will work well on soot also...
  8. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Yes. It might be etched in. Is there anything that will clean that?
  9. madison
    madison
    Expand Collapse
    Sep 12, 2008
    1,484
    93
    Loc:
    41.33°N 74.18°W and 44.67°N 111.0°W
    Try Rutland Stove Glass Cleaner, avail. at Tractory supply, home depot etc. It cleans and puts coating on that makes it easy to wipe off future stuff. I do not work for the company, but bought some the first yr when I had unseasoned wood.
  10. DexterDay
    DexterDay
    Expand Collapse
    Guest
    What were you using to clean it before? (Any ammonia products? Windex?)
  11. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    I guess I forgot to add the Rutland cleaners to the list of cleaners that I have already tried. I have some of that. It doesn't get
    this stuff off, but it does work pretty well for regular soot, etc. And it does leave a silicone coating that makes future cleaning a
    little bit easier, you're right.
  12. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    No, no ammonia. Although, I'm pretty sure Ammonia will not hurt this ceramic glass material.
    When I first got the stove, for about the first 6 months or so, I was able to keep the glass perfectly
    clean with Sprayway, at first (perfume grade alcohol, no ammonia), which is very mild. Great product for windows, by the way...
    Then later, I used the Rutland (blueish cream stuff), and after about 6 months or so, I started using SpeedyWhite.
    The guy at my stove store recommended it... It worked better than all the other products I had tried, so I statyed with it.
    I still use SpeedyWhite, but it doesn't get this superfilm off.
    The only thing that even came close to making a dent in it, is BarKeeper's friend. Which is a mild oxalic acid. But I have
    to use very hot water and 0000 steel wool with it and scrub for about 15 minutes to make a dent in it...
    So, my next thing to try, unless you folks can come with the answer, is to try a heavier concentration of oxalic acid;
    which means mixing my own. I've got some wood bleach, which is 100%. So, I'll dilute some and we'll see how that goes...
  13. Gunks
    Gunks
    Expand Collapse
    Oct 27, 2009
    219
    2
    Loc:
    Ulster Cty, NY
    I have a Scan 60 also and this method cleans the glass every time.
  14. HotCoals
    HotCoals
    Expand Collapse
    Oct 27, 2010
    3,429
    299
    Loc:
    Rochester,Ny.
    Burn some pine real hot with full air..don't put a lot in though.
    If that don't work use a razor blade..a new one in one direction only..do not flip the blade..dip in water for lube.
    It will work.
  15. mossycup
    mossycup
    Expand Collapse
    Dec 4, 2010
    73
    3
    Loc:
    Northern Illinois
    I use dampened newspaper dipped in fine ash and follow up with a dampened paper towel to clean up the muddy residue.
    If I still have a haze, vinegar on a paper towel seems to cut it pretty well.
  16. dwillistein
    dwillistein
    Expand Collapse
    Sep 10, 2011
    40
    0
    Loc:
    western NY
    If it is etched you really need to re-polish it. I've done this with cerium oxide powder (optical polish), water, and a felt bob on a drill.
  17. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Cool! Thanks very much for the tip. I'll see if I can find some of that. I just cleaned it today with Oxalic acid and it works pretty well, but the
    glass (ceramic) is still kind of blurry and ruff too. It's kind of like a bathroom window... I'll try re-polishing. :)
  18. billjustbill
    billjustbill
    Expand Collapse
    Dec 26, 2008
    125
    6
    Loc:
    Texas
    I'm wondering if the glass was installed backwards. If it is etched to some degree, it's going to catch everything if the rough surface faces the fire. Is this the only piece of glass it has?
  19. BrotherBart
    BrotherBart
    Expand Collapse
    Hearth.com LLC Mid-Atlantic Division
    Staff Member
    Nov 18, 2005
    32,190
    9,470
    Loc:
    Northern Virginia
    Didn't crawl through the whole thread but I use a water wet paper towel once a month when the stove is cooled down before a morning reload.
  20. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Hi Bill,
    Wow, I didn't know there was a front and a back to the glass. Yes, this is the only piece of glass in this stove. It's a fairly large
    piece (14" x 17" approx.) in the front door (Scan 60 woodstove). Everything was totally assembled when I purchased the stove. The inside is kind of
    blurry or frosty like a bathroom window and it is kind of rough, not smooth like it is on the outside (It was fine when new). So, I bought some glass polish that was recommended earlier and I have an angle-grinder tool that I used to use to polish my car. So, I'll use that and see if I can
    bring it back. I wonder if I should flip it around? If there is a front/back to the glass, then it was probably put in backwards!
  21. hoffa
    hoffa
    Expand Collapse
    Jan 5, 2012
    18
    2
    Loc:
    Ont Canada
  22. pen
    pen
    Expand Collapse
    There are some who call me...mod.
    Staff Member
    Aug 2, 2007
    7,693
    1,507
    Loc:
    N.E. Penna
    Sounds like this glass needs more than a cleaning and is etched.
    Also sounds like the OP has a plan. Redtail, let us know how you make out repolishing and how you do it.
    My glass is etched on both sides for some reason. Top, bottom, and center are fine. Interested to hear how you make out or if you can bring it back.
    Also, I changed the thread title so that it's more specific to your problem and searchable in the future.
    pen
  23. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Thanks, I didn't know about this product. I've been using SpeedyWhite and that works really well for the soot and so forth, but
    I think I'm actually beyond cleaning now. Oxalic acid actually does get most of the etched-in, baked-on gray film, but it's still
    real frosty and not smooth.
  24. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Okay, thanks Pen. It has turned into an "Etching" thread, you're right. :) Although, when I started out on this quest, I thought
    all I needed was a good cleaner...
    It'll be a week before I get the glass polish (I had to order it online), but I'll definitley let you folks know how it works.
  25. REDTAIL
    REDTAIL
    Expand Collapse
    Jan 26, 2012
    47
    0
    Loc:
    N. CA
    Thanks Pen, I'll let you know how it comes out. :)
    It'll be a week or so to get the glass polish (ordered online)... Sorry for the duplication. There's no delete!
Entire Site copyright © 1995-2016 - email to webinfo@hearth.com
Hearth.com and HearthNet are property and trademarks of Hearth.com LLC Advertising Information
