File life
FFDewey Posted By FFDewey, Mar 30, 2013 at 12:48 PM
  1. FFDewey
    FFDewey
    Member 2.
    NULL
    Sep 29, 2012
    16
    6
    Loc:
    SE Iowa
  2. smokinj
    smokinj
    Minister of Fire 2.
    NULL
    Aug 11, 2008
    15,981
    1,412
    Loc:
    Anderson, Indiana
    Seems the better you get the longer they will last. When I first started filing it seem like I would go through a file on just a few chains. Now it seems they last quite awhile dozen or so.
    Nixon and Thistle like this.
  3. Thistle
    Thistle
    Minister of Fire 2.
    NULL
    Dec 16, 2010
    4,206
    2,234
    Loc:
    Central IA
    Longer when you dont hit any rocks,embedded chain link,large spikes or other debris with the saw chain. I hit some hidden fence wire in a walnut stump last Fall,took quite a few sharpenings before all the teeth were back to normal again.I used Oregon files for many years,switched to Woodland Pro (made by Carlton I think) in late 2011,cost was a bit less for even better quality/longer life.Buying them in a box of 12 is much cheaper too.
    smokinj likes this.
  4. bogydave
    bogydave
    Minister of Fire 2.
    NULL
    Dec 4, 2009
    8,426
    3,446
    Loc:
    So Cent ALASKA
    Keep them clean, (I spray with starting fluid to clean them, out doors ;) )
    Only make chain contact when pushing forward, don't drag it back thru the cutter.
    Should out last a few chains.
    Good one should last a long time.
  5. FFDewey
    FFDewey
    Member 2.
    NULL
    Sep 29, 2012
    16
    6
    Loc:
    SE Iowa
    Thanks for the replys. Sounds like they will last awhile. I have been sharpening two chains that I rotate.
  6. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,367
    Loc:
    Michigan
    New chain: New file.
    MasterMech likes this.
