Firebox size
jeff6443
139
NJ South
Ok guy s and gals I read my manual . cant find the size of my fire box VC dutchwest med model 2478
first year burner in this house put it in 6-12-08
what are the dimensions of your firebox. wxhxd (inches)
Need exact dimensions. I'm guessing it will come out around 1.5-2.0 cu ft and those numbers come out to 2.7 cu ft.
Thats measured from the inside best I can do it med stove factory says 40000 btu
25/35 pounds of wood 20/22 inches 9 hr burn time
I'm guessing that the 14" height is off. You can't load the stove right up to the top plate. If that is correct, figure ~ 2 cu ft stove.
