Fireplace insert causing gas furnace thermostat location problem
reed102 Posted By reed102, Oct 19, 2006 at 4:02 PM
Thread Status:
  1. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    Installing a woodburning fireplace insert and I know it's going to cause a conflict with the gas furnace thermostat. The insert is not big enough to heat the whole house and we will be using the gas furnace to handle areas where the heat from the insert can not reach. A thought I have is to relocate the thermostat. Anyone else had to do this and what problems did you encounter.
  2. brian_in_idaho
    brian_in_idaho
    New Member 2.
    NULL
    Aug 23, 2006
    157
    0
    Loc:
    Jewel Lake (Sagle), Idaho
    As long as you have a spot that you want to locate it, somewhat distant from the stove, the install shouldn't be too bad. Like all wiring projects, it depends on what you need to do to run the wire to the new location. If you have access either below or above (attic or basement crawl-space), you can get some electrical boxes that clamp to the sheetrock to mount the thermostat.
  3. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    Fortunately, our home has a full basement and running wire does not present too much of a problem. I suppose there is some sort of a guide that heating and cooling people use on choosing the location best suited for a thermostat. I'll try to run down some websites cause I also have to consider the air conditioning in the summer.
  4. nshif
    nshif
    New Member 2.
    NULL
    Oct 7, 2006
    954
    0
    Loc:
    Pioneer, Ca (near Lake Tahoe)
    The best place for a thermostat is usually near the cold air return. What you might do if you want to experiment is get 50 or 75 feet of wire (its cheap), hook it up the the furnace and just run the wire through the house and experiment with different locations with the stove running.
  5. reed102
    reed102
    New Member 2.
    NULL
    Sep 19, 2006
    31
    0
    Loc:
    Greenville, Oh
    That is an excellent suggestion, thank you. One thing I just found while surfing the net are wireless thermostats. Might look more into those. Thanks again you have been very helpful.
Thread Status:
