Fireplace Xtrordinair 33 fast burn
maverick06
827
media, pa
Well, i figured it out!
This year my Fireplace Xtrordinair 33 seemed to be burning pretty fast. I originally thought it was because my wood was super dry. It burning very fast, even with the air way down. I finally figured that it must be the gasket was just worn out (after 4 years of use). I am burning 24/7 and since the stove is always hot, haven't done the dollar bill test.
Last night I reloaded and noticed the door was barely closing.
I noticed the latch that closes the door is held in place by a nut, and it was loose. So i just tightened it up (by hand) and now it is very tight. If I close the air it really shuts the fireplace down. I have to get used to where to leave the air control all over again.
But for those with similar fireplaces, Fireplace Xtrordinair 33 and 44 and the lopi declaration (probably a few others), this might save you some time!
Rick
Good info Rick. I'll go check mine tomorrow.
Happy New Year.....Som
If you need to make it even tighter take the nut,washer and latch off and take one
more washer off put latch back and two washers on than the nut.
