Anyone replaced the insulation/gasket on the back of the firewall behind the burnpot? If so, what material did you use?
I have an 10-year-old Integra that works great, but just noticed a small area--about 2 inches square--that's missing on the backside of the lower cast wall, just in front of the heat exchanger tubes. It's purpose I'm guessing is to keep the heat tubes from getting too hot and warping. I'd like to repair it with high heat insulation material, like head gasket material, with silicone, but for higher temps.
I can order a new piece that's made to fit ($36) which is fine, but a stove tech guy I talked to said the replacement insulation doesn't hold last nearly as long as the original. Anyone have any thoughts on where to get a small amount of high temp insulation--about 1/32 thick?
