Firewood carrier suggestions?
tlhfirelion
442
I'm on the lookout for a very durable firewood carrier for when we bring firewood up from the rack. I've bought the cheap pseudo-canvas ones from lowes that are overpriced for lasting a winter, maybe two. I considered making my own but wasn't sure if leather or canvas would be a good option, or if there is a bombproof one online somewhere. Anyone have a recommendation?
Thanks in advance for your assistance.
I use 5 gal buckets, can't fit a ton but it is easy carrying 2 of them at a time because of the handles, so, how about a basket with handles or a big plastic container.....I also fill wheel barrows and keep it covered in a good spot for me to get it.....
A plastic tote the same size as your firebox. It contains the wood drippings and each full tote is a full stove load. I am considering building a wood box for next to the stove that the tote will fit into. Load tote, store in box next to stove - ready for action. Dump the crud the next time you are pulling wood off your stacks.
Ditto on five gallon buckets. I've even scrounged a couple metal ones from the job site that iron workers get their bolts in. They have a rustic look. The best thing about buckets is they hold the mess.
Thank you for everyone's reply. I do like that carrier from LL Bean but the metal bucket idea sold me. I need big ones tho as I'm usually loading up larger logs. I keep small kindling in a bucket next to the stove so just lots of big logs. I think the bucket will do the trick. Thank you again for the feedback!
I use rubbermade totes. I have like five of them designated for firewood. I have a rotation. It's not perfect, but it works for me. Then I have a copper tub near the stove.
I had one of those totes from Lowes . . . lasted four or five years.
Just bought the LL
bean tote . . . figured if it does not last at least as long as the Lowes bag I can return it for a replacement.
I use blue recycle bins and stack splits vertically in them. That way all the dirt & crud doesn't collect on the bottom splits and you can grab any split at any time, instead of just what's on top. 2 bins a day usually.
Used to be Rubbermaid bins, but they got brittle in the cold & hand grips would break.
I do like the Ikea bag idea. Would be easier on my back carrying 2 of those per trip vs one recycle bin. May have to try that out...
This one seems like a good idea.
http://www.condar.com/backsaver_fireplace.html
thinking about it for myself
Ok, the name got me to look, but I just don't get it
The load is on the neck, shoulders and extended arms. Don't see how that saves the back.
Loading off the bottom of a stack means you're squatting down until loaded then doing a loaded power squat to stand back up.
Then you get inside & you can't just put it down, so you have to unload one piece at a time (one hand) or try to dump the whole load into another container. <>
Reactions: Ashful
the bag I have is made by Firl Industries http://www.firlindustries.com/ specializing in canvas products to include fire and rescue items among others. Wisconsin based, items made in the good ole USA. I did not see a virtual store front though, so you would have to find outside vendors like plow and hearth.
