fisher wood stoves ul approved
fishead
1
UP of MI
we are looking for a fisher stove that is ul approved for ins. purposes.We found a mama bear with the cathedral doors,but it has no ul sticker,is there a chance that it was removed when,if it was refurbished.From what I've read the doors were changed around the time they started the ul approved stoves.
It doesn't matter if it was approved or not without the sticker there is no ul approval. For stoves where the company is still in business you can occasionally get them to reissue a sticker but it will not happen with a fisher.
Reactions: coaly
The UL listed stoves have a shield on bottom and rear with tag affixed to rear shield. The corners will be bent instead of using angle iron on the corners that become legs. Most fabricators continued to make the old style that was not tested to UL listing standard with the Cathedral doors after 1980. They were $100 cheaper when it was not necessary to use a UL Approved stove on non-combustible hearth or cement floor with non-combustible wall behind it.
The stoves were tested by different labs for the areas they were in before the UL testing specifications were adopted nationwide. They are not an unsafe stove, they just were not tested to the standard required by most jurisdictions now.
This is the Listed version;
The optional leg style will change the look. Here is a listed Baby Bear shown with Fireplace Leg option;
That is the stove body to look for. They are also known as Model VI.
Here's a Mama you're looking for with standard legs;
VI Tag on Mama.jpg VI Tag on Mama with clearances.jpg Tag on same stove.
I agree but if the insurance company want it to be ul listed it needs to have the ul tag plain and simple. Nothing else will matter to them.
Reactions: coaly
Amen.
