Freezing my forced hot air pipes.
rphurley
435
Central/Eastern CT
Hello,
I recently in stalled a I3100 in my living room. I do worry about the forced hot water pipes that go to my bedroom as they run over my garage and I can only assume that they are pretty well insulated, If my heat is not kicking on so much, because of the stove, then how concerned should I be that these pipes might rupture during the cold season. My neighbor has a same situatuation and she tells me not to worry about it. Would putting my thermostat in the bedroom help it to kick on more frequently?
My very first year burning wood in my own house(about 25 years ago), I planned on saving a pile of money for me and my wife by heating with wood. Woodstove was nice and toasty, unfortunately all the pipes in the house froze up and cracked in about 100 places one bitter cold January night...needless to say, I could have heated with oil much, much cheaper than those repairs cost me....
I say, don't ignore the problem. Do some investigating and figure out if you are likely to have a problem, and if you are, figure out away around it. More insulation, a pump that keeps that water moving, running the heat thru the pipes, pipe tape etc....all those options will be cheaper than fixing it after-the-fact.
Thanks Mr Ed,
I think I'll talk your advice and the advice of others in this forum and thouroughly investigate my options.
I appreciate you sharing your bad experience.
Rick
