I am making my last car payment this month which will free up the money to buy our gassifier. I had been planning to purchase a Baxi (Tarm) Solo Innova 50 and have been planning our install accordingly. Due to some recent favorable financial circumstance, we can afford to finance a Froling Turbo 3000 50 unit instead, which we will acquire from BioHeat USA. Does anyone know what if any differences there may be in the install of the Froling rather than the Tarm.  I've read Mr. Brownian's Froling Experimental Install posts a number of times. That installation looked both impressive and a bit daunting.
I saw on a UK site the output for the supply pipe was listed as 1.5 rather than 1.25 inches. Do I need to use the larger pipe to run between the boiler and the forced hot air furnace and DHW tank where heat exchangers will be? This may possibly make a difference in sizing an expansion tank as I have a longish run, about 50 feet, and then back, to the furnace and DHW. BioHeat's piping diagrams are the same for either unit and make no mention of a pipe size difference.
Are there more relays and electrical connections that need to be made to provide input for the many readouts the Froling provides? Is there anything else special or different I'd need to know about for the install? I have a thousand gallons of pressurized storage waiting, and am now sizing all the other components prior to purchase.
If anyone else out there has installed a Froling or has knowledge of their maintenance track record, I'd appreciate any input or suggestions. The potential life span of the electronics does worry me some. My old high end stereo components from the 1970's are difficult to get repaired or find replacement parts for. I really don't want to repeat that experience with the Froling. Heat and electronics are a poor mix as you probably know. On the other hand the Froling units look very well built and designed, so I think I'll take the plunge, unless one of you can scare the dickens out of me. Thanks.
Mike
Mike
