Galvanized flue
laynes69
2,677
Ashland OH
I just wanted to verify that a galvanized pipe for a flue pipe is a no no on a solid fuel stove, or furnace. Somebody was saying that galvanized is okay, and to replace it when it leaks. I advised to replace the flue with standard painted flue pipe and not run the stove without replacing it. Working with galvanized, it can produce toxic fumes with heated. I also know it may look fine on the outside, but crumble when touched. A very dangerous situation.
sometimes HT pipe has a galvaized exterior, and a stainless liner. That stuff is ok. Regular galvanized single wall snap pipe is not ok for connector pipe for the reasons you stated above.
poooooooooooooooooooooooooooooooook said:
whats HT?
HT is the correct term for high temp pipe. Class A is a generic term for HT and regular pipe (the 1700* stuff).
