Garn air intake question
Kemer
213
Northeast Pa
Because of my situation I had to run my air intake like this.An elbow off the collar going vertical and 4 ft. of 7" pipe then another elbow going to horizontal then 8ft. of 7" horizontal to outside.In the book it says 2-elbows and 12 ft. of pipe is ok but I think I am pushing it to the max.Most installs only use 2-4 ft. of pipe to the outside running horizontally.I am told a elbow is equal to 5 ft. of straight pipe in friction loss.My question is How many percent loss do I have compared to a standard installation? And how do you think this is affecting my performance?
I am told that I can pull air from the room as long as I have enough air in the room.I will have the original opening still in place.The most important question is "Is there any way if the unit huffs, can it blow back in through the air intake since it would be open to the room.
So your real question is what is the friction loss in 12 inches of 7 inch pipe. If you have an issue, Dude it isn't an extra foot of pipe. If it makes ya feel better, change it out to 8 inch. but it will be a waste of you Saturday.
Its 12 FEET Of Pipe And your wrong it could be an issue
Sorry I though 2 elbows and 4 ft of pipe + 8 ft of pipe was 13 ft of pipe Sorry I transposed the 7 & 8. Now it's two feet over, the 12 ft + two elbows. Got a duct calculator in front of me and I believe you can't even measure the difference of the two in velocity or static pressure. Cal Martin and ask him? Sure there is some fudge built in.
I did call and I am over the limit.My question is How much does this affect my performance and by how much over a standard install.It may come to moving the unit to over come this problem and I want to make the best decision.
I was told by This warm house that it would be ok to install this way and now I find out differently.apparently I might not be getting the volume of air that is recommended because of the length and elbows combined.I can disconnect the pipes and just pull air from the room but I worry about sucking the heat out of the room and having a open pipe .Garn says its ok to do this but I'm a worry wort and want some other opinions.
Harry
Kemer, If I were doing your install I would be using 8" pipe and ells and reducing at your fittings as needed.
I know you would be safe there.
A Garn needs 300+cfm at full burn and pulling, not pushing, that through 7" pipe is iffy with the 2 ells in it. Personally, I would rather have the intake coming from outside for the simple reason that you are not using conditioned room air and wasting the heat in it.
Thanks Heaterman.I can always count on you for a intelligent answer.I can go as large as I have to if needed will a 10"pipe be better? Can I have my plumber test my system afterwards and how would he do it. would the 300 cfm be at the exhaust or intake? If you recall I have a problem with my vertical chimney and embers.Garn thinks I am not burning hot enough because of the intake.Whats your thought on this?
Thanks again
Harry
The result of the garn will be that it wil puff sooner and longer with more intake resistance. Of course it will depend on the volatility of your wood, dryer smaller loose packed splits will make it worse. As suggested if you need the ducting to get outside air, go larger to decrease the resistance.
Hi Jim,
My flue temps are around 450* but they went as high as 530* once.It looks like my options are 1.switch to a 8" or bigger pipe.2.install a tee at a elbow and run another 7" pipe parallel to the existing one or 3.install a tee at elbow and go straight up and thru roof with a cap. or build a garn barn and get it away from the house and let it spark away.I was thinking would opening the door to the safety latch while it sparked be the same as letting more air in?Of course this would only be a way of testing before I when through all this or is there a pressure thing going on here and that won't prove anything?
Ps I get very little puffing.I can only hear it outside
Your temps sound OK. If the Garn is not puffing substantially or at all, then circumstantially it appears you have enough inlet air flow. Up-sizing the inlet piping will certainly go a long way to compensating for the extra restriction due to length and turns. There are ways to test the flow using a manometer, but it's probably not worth doing that.
Pulling air from the room is possible, providing you have adequate inflow to the room. Otherwise you will have the same problem (restricted inlet flow). Opening the door does not help because it disrupts the distribution of air flow to the nozzles. I have opened the door to stop heavy puffing, but only for a few seconds.
Jim,
The root problem here is too many embers coming out of the chimney.Garn seems to think I don't have enough air.During the day time my system seems to work great.It's when I look at the chimney during a night time burn.I can't relax knowing there is embers coming out.I've had almost 200 fires and no problems as very few embers reach the roof never the less it is un nerving.Remember I have the vertical chimney Garn.Have you ever looked at your horizontal flue at night?Do you see any embers.I know they are contained in a barrel but do they still come out?I do seem to see less embers with a higher flue temp hence a hotter fire? and more air a more complete burn?
Harry
Hi Harry:
Yes, with my horizontal flue....all 7' of it out to the garbage can (no screen on the can yet at all), and about 5' of pipe on the air intake (straight into the garn, no elbows), I still see the occasional "spark". Not sure what you mean by an ember. They will come out and blow around in the "flue breeze". Yes, they leave the can (no screen). Would they leave the can with a 1" or 1/2" mesh on it? I'd think so. They don't last long....maybe a few seconds. Can they start a fire? Obviously not this time of year. After three weeks of heat in August without rain? That's a good question.....
So if you are trying to remove these totally and absolutely, I still see them....and I don't think I can have anything shorter or more air.
Now, if you are getting "coals" or anything with significant mass....then I think that's a different story. Do these things leave your roof area? You have asphalt shingles?
Sometimes bigger things will get pulled through, and I can hear them rattle through the squirrel cage blower....but I have not seen any big "coals" sitting in the barrel ever.
Harry,
I see the same a pbirger is seeing. You can click on my signature link and see my set-up pics.
Rick
A couple questions for you Kemer....
How dry is your wood? Reason I ask is that I have noticed on a number of Garns that if the wood is very dry or if some of it is getting a little dozy, it will tend to crumble as it burns. When these pieces breakdown and fall apart in the firebox during operation, sparks will sometimes make it all the way through the entire 50 feet of heat exchanger tube and exit the flue. Mixing a little "greener" fuel in with the load on top of the very dry stuff will retard the combustion process a bit and maybe prevent some of the sparks from entering the air stream.
Have you upsized the intake yet and have you noticed any effect?
I wouldn't recommend going completely vertical with your intake as it would be possible under some circumstances to create a reverse air flow back up the intake when the blower is off. This would allow relatively hot gas leftover in the combustion chamber to find their way out of the intake which of course is only single wall pipe and not made to handle any heat.
Hi Guys,
To answer a few questions yes I do have asphalt shingles.It is a good chance it might be my wood.I have about 6 cord of pretty dry stuff and some of it is punky on the outside but very solid wood.I was hoping not to have to throw this stuff out 6"solid oak with maybe a 1/4" of punky outside.I do have some better stuff to try and that's what I'll do.Heaterman I will take you advice on the vertical intake and run a 8"but it's cold here now and I want to wait for a little warm up before I take it apart.As far as how much embers and what kind some time it's like the fourth of July,well not that bad but I'll get 100 floaters in a burn,99% don't reach the roof but some times they do.Chances of it causing a fire is one in a million but so is the lottery and and there is always a winner.I've been doing construction for 43 years now and to me it's not a big deal to relocate the garn.I just like the idea of having it attached to the house and can build a fire in my under-ware.If I build a bump out with a metal roof it might work out and free up some boiler room space as long as the wind doesn't blow the sparks back to the house.I just wish I knew about this before.I'll try my options first and then play it by ear.
Harry
Harry - you are still welcome to come up and see my unit during a burn. I do see small incandescant particles make it to the discharge elbow and blow around briefly, but I have not seen any "fireworks" or anything large enough to be a hazard or concern.
BTW - I burn just about every kind of (dry) wood imaginable, including some pretty punky stuff. I also burn a lot of Eastern White Pine and Hemlock. In my experience the wood type has not made much difference in the number of glowing particles I see at the discharge point.
Jim,
Thanks for the invite. What you tell me helps a great deal.I didn't want to think I had to be that particular on my wood other then mc.So I 'm starting to narrow this down before I start ripping and tearing.I would like to start right at the back of the unit with 8" intake pipe but it tight back there and I over screwed,glued and taped the pipe.Usually if I think about something long enough I can come up with a clever fix.Garn thinks it's not a complete incineration because there emission's are low when things are set up right so it keeps pointing to an air issue.I really like my Garn and would like to get this fixed.Right now I'm not really getting the most out of it and find myself holding back from loading it up.I only load it up about half way and was wondering if I loaded it up higher would that block the nozzle and keep the embers down a bit.Just to clarify again I only see embers when it's pitch black out.
Harry - I would suggest you leave the first section of intake piping in place and upgrade the diameter from the first seam on out. Up-sizing those elbows will help with the flow especially.
Adding my $.02 here.
Hankovitch from SW Wisconsin communicating. I just got my GARN 2000 up-and-running the first week of January. We will be heating three 'floors' of a 36' x 104' Barn/Home with this unit.
I burn 100% kiln-dried pallet wood which I get from a local company where they have a large band saw they use to literally cut apart pallets, and then they rebuild pallets with the usable wood. The splintered, cracked, busted or odd-sized pieces they put in ~4'x4'x4' 'boxes' and either burn themselves to heat their 36,000 sq ft warehouse or sell to people like me who want to burn wood but are too lazy to cut, split, stack, and dry tree wood. The pallet wood comes with nails, but virtually all nails are IN the wood (nothing sticking out) since they cut the pallets apart and the band saw blade just cuts right through the nails.
My Burn Experience follows........For the first 10 days of burning I experienced an absolutely HORRIFIC problem with puffing/huffing for 15-30 minutes into my burn. With a reasonable or large wood load I found that unless I leaned on the door to keep it shut for the first 15-30 minutes of the burn I would have my Garn Room FULL of smoke. Alternatively if I put in a very small load of wood (enough for a 30-minute-burn-to-ash) could I burn without huffing. Boy was I frustrated. I was thinking I might have to cut trees, haul wood out of a forested area, split it, stack it, dry it.....etc......not what I wanted to do. I can drive 16 miles, get 3 'boxes' of wood (1.5 Cords) loaded into my horse trailer, haul it home, take the boxes out using our Bobcat....and in an hour I have 1.5 cords of wood in storage. The cost of the wood is approximately twice the cost of the gasoline to make the round-trip!
Can you tell that I am frugal and lazy?!
I scoured this and other Forums to find out what others had done to minimize......or maybe even eliminate(?!!) Puffing.
Bottom line from a half day reading various forums ------ The problem was TOTALLY SOLVED (emphasis intended) by simply building and maintaining my wood load in the rear 75-80% of the Garn's burn chamber. Boy, was I relieved!
I use about 24" long pieces of pallet wood (I cut all pallet pieces in half), carefully load/stack/ the wood into the chamber leaving about 4" to 6" of space from the end of the wood to the secondary burn chamber, and light it up. NOTE: when I say I carefully load the wood I mean I load it with as little air space between pieces as possible.
I do use the extra Burn Brick, not lying flat but on-edge, placed in about 3" from the door.
I always get a smooth, even, efficient burn with not even a hint that the unit may start puffing and huffing...nothin' but water vapor coming out of my horizontal flue.
I hope this helps others who have similar problems with burning wood which would be considered 'too dry' by much of the wood burning community, and I thank those who provided the solution (it was not my idea, I just used what others were kind enough to share, and am now passing it forward).
What Hankovitch is witness to is the fact that it's easy to get too much of the wood "involved" in the fire at one time in a Garn. This is due to the volume of air moving through the combustion chamber. As he said, leave as little air gap between you wood as possible especially if it is ultra dry or fine diameter. With smaller pieces a person can easily get too much surface area exposed and soon even the Garn's combustion motor can't supply enough to satisfy what the burn rate wants to be. Puff the magic Dragon appears and you get sparks and embers galore out of the exhaust + unnecessary smoking because the unit is actually going positive/negative pressure in the firebox trying to "breathe" and get enough air.
I'd say Hank's got the method pretty well nailed down.
Thank you. It's now been two weeks since my first burn with my all kiln-dried wood pile shoved close to (within 2-4" of) the ceramic liner of the secondary burn chamber. I've had only a single burn (out of a couple dozen) where I had about four belches (puffs?!), otherwise the burning of my pallet wood has been blissfully uneventful.... so all's well. Thanks to everyone who contributes to the Hearth Forum!
