Hi Guys- I'm mainly a wood burner but wanted to get the opinion of some gas guys. I do have a small Hearthstone gas stove in a large upstairs bedroom.
So- I have a brick fireplace that had a "slammer" wood insert in it. It was basically a shoulder season stove and emergency heat stove. No piping, etc- it used the masonry chimney to vent. I closed up the chimney with a cap after the draft from the unit when it was not used was too much too bear, so the stove is being removed.
I actually did like the idea of a heat source there. I know I could put a better insert or stove there, but that would mean a metal chimney, etc.
Is there a low cost gas alternative that would suit me instead? It would have to seal well in the hearth to avoid the draft issue, so I believe gas logs are out of the question. The ability to vent to the masonry chimney to keep it low cost is appealing too.
Thanks
Thanks
