    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. QandA New Member
    Question:
    My wife and I are looking to replace our current woodburning fireplace with a gas insert fireplace in our 200 sq. ft family room which is partially open to the kitchen area. I have been to several fireplace stores and now am totally confused. One salesman says an efficient radiant heat gas fireplace is all you need while another says a fireplace with a blower and thermostat is a logical choice. Based on the description of the area we want to heat what in your professional opinion is the approach we should take.
    Answer:
    Basically:
    1. A gas log in an open fireplace is a solution only if you intend to use the heat on an attended basis for 1-3 hours per day. In this case- an unvented or partially vented log may do
    2. A sealed- and vented (b vent or direct vent) insert is a great solution- which can be used as much as you want- and will provide a greater level of safety (no open fire)Of course- #2 costs a bunch more..but if you have the $$$- it's a good way to go. Most of the manufacturers on HearthNet sell the gas Fireplace Inserts. Jotul- Travis- HearthStone- etc. Others sell the unvented gas logs.
    #1
    Helpful Sponsor Ads!
Thread Status:
