    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. Scotty Overkill firewood hoarder
    central PA
    double check you stove pipe and flue pipe, and just as important CHECK ALL OF YOUR SMOKE DETECTORS AND CARBON MONOXIDE DETECTORS!! Change the batteries and clean as needed. Even if you have hard-wired detectors, you need to ensure they are clean and are working properly. I consider taking these measures to be more important than anything else you can do to ensure you and your family's safety. If you do not have these devices in you home, SHAME ON YOU! Get them, especially as a woodburner! Be safe this heating season!!
    #1
    Helpful Sponsor Ads!
    Joful, MasterMech, jharkin and 8 others like this.
  2. firefighterjake Minister of Fire
    Unity/Bangor, Maine
    Guess it goes without saying . . . but I really, really, really like this thread.
    Scotty Overkill likes this.
  3. mellow Minister of Fire
    Salisbury, MD
    I agree 100%. You can never be to safe when you invite a fire into your house.
  4. Scotty Overkill firewood hoarder
    central PA
    Jake, I am doing the job at home tonight myself (we have hard word detectors, gonna clean and do the self test, as well as a related smoke test on each one). Just felt it was worth mentioning. I figured you and tfdchief would appreciate this. I was a volunteer firefighter, and still answer the call of duty should the need for me arise.
    Backwoods Savage likes this.
  5. Scotty Overkill firewood hoarder
    central PA
    There's a member (stoveguy2esw, I think) who has a line on his signature that says it best......"if you're going to invite fire into your home, do so with the utmost of care".......couldn't agree more with that statement.
    Backwoods Savage and PapaDave like this.
  6. Beer Belly Minister of Fire
    Connecticut
    Thanks for the reminder......I've got the stove ready.....now, to prep the house
  7. BrotherBart He Who Moderates
    Northern Virginia
    I tested the smoke detectors yesterday morning. When I fried bacon for breakfast. <> Interconnected house, generator shed and garage detectors. The joint sounded like an arcade.
    milleo and Scotty Overkill like this.
  8. BrowningBAR Minister of Fire
    Doylestown, PA
    Mine automatically alerts the fire department unless I call afterwards. Found this out the hard way...;em
  9. etiger2007 Minister of Fire
    Clio Michigan
    I agree,, and I still have a fire alarm I need a battery for thanks for the reminder.
  10. begreen Super Moderator
    South Puget Sound, WA
    Good reminders. Also check the fire extinguisher to make sure it has a full charge. And take the candles off the stove top!
  11. Scotty Overkill firewood hoarder
    central PA
    Yes, wife has those candles on our stove also......great reminder on the fire extinguishers as well, BG!
  12. PapaDave Minister of Fire
    Done, done, and done.
    Good pre-season thread, for those looking.
  13. gmule Feeling the Heat
    Conifer Colorado
    X 2
  14. HollowHill Minister of Fire
    Central NY
    How do you test the smoke detectors? And clean them? This is a great thread!
  15. Scotty Overkill firewood hoarder
    central PA
    I always clean the detectors by blowing them out with compressed air (on a medium setting) with a small portable compressor I have. I then do the self -test mode on the detector, and also do a real smoke test (most of the time a match right below the detector will do the trick, or a smoldering piece of cardboard). Also make a habit of looking at the indicator lights on your detectors, to see if one has gone off when you weren't around.
  16. BrotherBart He Who Moderates
    Northern Virginia
  17. WellSeasoned Minister of Fire
    Eastern Pa
    Thanks for the reminder! I did a quick sweep on the chimney in case of a birds nest,ect, and cleaned around the stove. I will now immediately check the extinguisher and smoke alarms.
    Update: smoke detectors, co, extinguishers up to par!
  18. begreen Super Moderator
    Love that shot. It goes under, "Honey, next time try to keep the room temp below 100::F." or "Do ya think we may have oversized the stove a bit too much?"
  19. Scotty Overkill firewood hoarder
    central PA
    Yeah, those candles were just a tad warm.......almost looks like something from an old Tom and Jerry cartoon!
    etiger2007 likes this.
  20. corey21 Minister of Fire
    Soutwest VA
    Very good thread.
  21. DexterDay Minister of Fire
    NE Ohio
    Stoveguy2ESW is Mike Holton, Senior tech at Englander and I couldn't agree more.
    Great thread Scotty....
    3 Fire extinguishers in the house. One near each stove 3 C/O detectors, and 3 Fire/Smoke alarms. Can never be to safe.
    I plug all my flues, pellet and wood. To keep the bee's amd any other critters out. Had a bee problem 2 yrs ago in the Quad!!! Never again.
  22. Backwoods Savage Minister of Fire
    Michigan
    Great thread Scott. Something to do each fall.
  23. Backwoods Savage Minister of Fire
    Michigan
    You can also use the compressed air in a can like you use on your keyboard.
    MasterMech and Scotty Overkill like this.
  24. Stump_Branch Minister of Fire
    MD
    For myself its a general pick up time as well. I like to get kindling ready, after all it just falls from the sky. Clean out the ash can, make sure there's no holes. Clear a spot out back to eventually dispose of. I found for two years now running out in the cold night with a rake trying to get a spot cleared
  25. Jack Straw Minister of Fire
    Schoharie County, N Y
    Check the dates on your smoke detectors, I think they are only good for 10 years. I changed all of mine last year, they were way out of date.
