Carl said:Don't know about your saw but some of the older saws I have used had a roller sprocket on the end of the bar which needed greasing with a small grease gun made for the job. One should have been included with the saw if that is what it means? Haven't seen one of these for quite some time.
pinewoodburner said:Lowes sells the Rancher and they also sell the little grease thing, it is about $10.00
kevin j said:Most don't grease anymore. Rollers are lubed by bar oil.
Some bars have no grease hole.
The balance between better lube with grease, vs. not lubing regularly and getting dirt ingression through the hole.
I never use the grease luber.
I have heard, and makes sense, that if you start greasing, then need to continue. The grease working outward forms a dam that prevents bar oil from getting into the rollers, so if stop applying grease, the bar oil can't get in. I have no first hand, no knowledge of any actual testing, but it makes sense to me.
Just run a good quality bar oil and go to work.
k
bjorn773 said:One argument for greasing is that while the oil will lubricate the sprocket, it will not push dirt and contaminants out of the bearings like greasing will. Just my $.02
