Harman P38 OAK
m159267
Burning Hunk
Mar 12, 2009
218
East-Central MO
I have a question concerning the Harman P38 OAK. The kit recommended by Harman for the P38 includes a 2 3/8" ID flex pipe to run from the stove to the outside. The inlet on the stove is at least 3" in dia.. This requires the pipe to be merely 'stuffed' into the opening. Is this really correct? Has anyone actually placed a flex pipe with a diameter that actually fits over the inlet? I have used the recommended setup for several years but it just does not seem correct.
well, the pipe is meant to be put into the opening.......I dont RTV it, as at some point, you may want to remove said pipe to check the intake damper, or the pipe for an obstruction.......I guess you can RTV it, but you will desroy the pipe if you remove it at a later date, most likely........
