Harman P43 Pressure Problem
Pellet Boy
2
MA
Anybody run into a problem with your pressure or vacuum;
  • I have replaced the pressure switch and the filter in the hopper
  • Cleaned stove thoroughly and pipes
Stove does not start on auto
  • Cleaned igniter also
Started stove with propane torch
  • Feeder will not run unless I cover the intake on the back so I guessing there is a vacuum problem
The only way to keep the feeder running is to cover the intake on the back but then the heat exchanger blower wont run When I turn to auto the blower come on and we get a lazy flame.
I took a cover and drilled 4 1/4 in hole in it which seem to keep it running for now.
I Am thinking a gasket may be leaking which introduces to much air with the intake wide open hence reducing the intake with the 4 hole cover appears to be the right pressure,.
Can anybody tell me if I am on the right track but it still doesn't solve the igniter problem I guess there are 2 issues here
Also I have had the stove for 6 years and was working fine when we fire her up for the first cold weather this problem just developed.
Ant thought or assistance would be appreciated
have you removed the fan cover behind the ash pan and cleaned fan and exhaust tunnel? Also is vent piping clean from the stove all the way thru the wall to the cap? Sounds like a plugged flue/vent pipe to me?
Thanks for the imput , I have done a complete cleaning of flue and stove. might have to break down and call service person
Is your hopper lid gasket good and free of pellets? Did you just remove the trap door on the side of the feeder to clean out the fines? If either of these are not secure and sealed it will give a vac leak. Had you just cleaned the stove prior to this problem or had you just come home and it was not running?
