I have a Harman p68 pellet stove which I cannot get to fire up. I hot wired the auger motor and it works and then replaced the pressure switch but that didn't help. If I run the TEST mode the auger does not run. If I run the stove in TEST mode I can get the auger to run by operating the switch manually. At no point has the igniter ever worked. Everything else seems to correct but it will not light. Any ideas?
