Harman Pellet Stove Flame Guide
Lumhqa Posted By Lumhqa, Feb 18, 2013 at 6:39 AM
Thread Status:
  1. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    My Harman flame guide gets lifted by the pellets and pushed at an angle that leaves the guide dangling off the front of the burn pot. This occurs mainly overnight as I can see the pellets build up during the day. I can level the pellets burning during the day. This occurs even if the burn pot is clinker free and carbon free. Any suggestions that I might try?
  2. Hoot23
    Hoot23
    Minister of Fire 2.
    NULL
    Mar 28, 2012
    868
    129
    Loc:
    Alfred, Me
    What model Harman? What's your feed rate? And scrape that pot really good. Something is pushing them up.
  3. frankie
    frankie
    Member 2.
    NULL
    Jun 12, 2012
    92
    2
    Loc:
    Stroudsburg Pa.
    I had that problem on an Accentra. Clean the grooves in the flame guide so there is no carbon and shove some 5/8 asbestos rope down on top of the guide. Make sure you shove it in enough. That solved it for me.
  4. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    I have a Harmon Accentra...thanks for the quick responses. I clean the groves removing all carbon buildup and have moved my feed rate down to 2. I run full time on stove temp and have adjusted that up as well as down trying to see it that will make a difference. The 5/8 asbestos rope idea sounds interesting. I don't get the discription of shove it down on top of the guide. Would you be willing to clarify?
  5. frankie
    frankie
    Member 2.
    NULL
    Jun 12, 2012
    92
    2
    Loc:
    Stroudsburg Pa.
    Cut the rope the width of the guide. Lay the rope across the top of the guide. The rope will then be in front of that little gap between the guide and compass. Take a screw driver and push it as far down the top of the guide as you can. between the guide top and the compass. That is where you want it to go. When done you will see the guide is somewhat tight.
  6. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    Frankie thank you for the directions and will give it a try and let you know.
  7. Lousyweather
    Lousyweather
    Guest 2.
    NULL
    also, your friendly local neighborhood Harman dealer might have a Flame Guide Bracket, part number 2-00-247435, which does a good job of retaining the flame guide, even when the pellet is cohesive and pushes the flame guide up.......should be around 23 bucks or so....
    Defiant likes this.
  8. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    thanks for the information and esp the part number
  9. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    I tried the idea and it seems to be working (only day 2 however)..I am wondering if I followed your directions correctly. When I first tried I managed to set the rope with the screwdriver in ok fashion on the ends, however when i pushed the rope in the middle to pushed well toward the rear of the flame guide and didn't look like I should be moving the rope that far back. I retried by securing the 2 ends with the screwdriver and kept the middle of the rope even with the screwdriver tucked ends. Does that match your idea?
  10. frankie
    frankie
    Member 2.
    NULL
    Jun 12, 2012
    92
    2
    Loc:
    Stroudsburg Pa.
    As long as it is tucked in. I push the center in some and then the ends so it is even then repeat the same process. After that I put another piece in and insert it the same way. The second piece is probably not needed but I do it anyway.
  11. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    First piece is still holding fine...it has also stopped the pieces from falling out the back side of the burnpot....many thanks
  12. Lousyweather
    Lousyweather
    Guest 2.
    NULL
    you are welcome! ;)
  13. 3650
    3650
    Minister of Fire 2.
    NULL
    May 8, 2011
    620
    128
    Loc:
    midwest
    If your flame guide is being pushed up it means you need to clean the carbon hump off your pot and the grooves in the guide. I use this as a measure that lets me know time to do some carbon scraping. If you wedge something in there that doesnt allow that guide to move I would think you are going to be moving that pressure to the auger causing more stress on it. Just my two cents.
    Defiant likes this.
  14. mascoma
    mascoma
    Feeling the Heat 2.
    NULL
    Jul 23, 2008
    326
    3
    Loc:
    Upper Valley NH
    It the guide warped or cracked?
    Only time mine has moved is when it did both and didn't sit on the burn pot correctly any more.
    Defiant likes this.
  15. tonyd
    tonyd
    Feeling the Heat 2.
    NULL
    Aug 8, 2008
    345
    45
    Loc:
    Hughesville Md
    Pellets shouldn't get close to the flame guide. The pellets should be burned way before they start moving the flame guide. If the pellets were moving my flame guide, there is Something wrong.
  16. Lousyweather
    Lousyweather
    Guest 2.
    NULL
    not necessarily something wrong...a cohesive ash can push up rather than out. I should laso say though that you should check your burnpot as mentioned above, because they *might* be correct. The part number I gave you is a Harman number, and will solve your dilemma if its not carbon buildup in the pot
  17. Joe and Kelly Tomeno
    Member 2.
    NULL
    Nov 13, 2012
    103
    5
    Loc:
    NY
    I'd like to see what this looks like...
  18. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    Definitely not carbon buildup. I clean the stove burnpot weekly making sure there are no clinkers. I am wondering if the control panel has something to do with the problem.
  19. Lousyweather
    Lousyweather
    Guest 2.
    NULL
    nah.....doubt it.....most likely just an elevated chloride content causing clinkers.......tho I would like to point out that its not clinkers that you scrape out, but rather a hard carbon scale that adheres to the burnpot....the clinkers actually can be draged out easily....not so the carbon
  20. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
    I appreciate your interest and comments. What I am calling clinkers more than likely are carbon deposits as I use a screwdriver to wedge them of the bottom of the burn pot and also the sides. I am planning of seeing the Harman dealer for the part you recommended and will post the results..thanks again.
  21. Delta-T
    Delta-T
    Minister of Fire 2.
    NULL
    Feb 27, 2008
    3,144
    580
    Loc:
    NH
    i would suggest placing the feed adjuster at about 4ish or slightly higher to help keep the fire out in front of the auger a lil farther...if the problem is carbon/klinker having the low feed rate is gonna help it form right where the auger can push on it...devilish I say...can also be a contributer to the dreaded "high pitched squeel" like fingernails on chalkboard...devilish X2 I say. I fthat doesn't work do not be afraid to give the stove a talking to...you may laugh, but it works.
    Lumhqa likes this.
  22. Lumhqa
    Lumhqa
    Member 2.
    NULL
    Feb 6, 2013
    29
    0
  23. Delta-T
    Delta-T
    Minister of Fire 2.
    NULL
    Feb 27, 2008
    3,144
    580
    Loc:
    NH
    threaten the stove with a visit from me...misbehaving stoves dislike me like a camel dislike a butcher.;lol
  24. Scalini
    Scalini
    New Member 2.
    NULL
    Mar 9, 2014
    2
    0
    Loc:
    Green Bay Wi
    I had this problem as well. I found that the Flame Guide Plate wasn't sitting down on the burn pot correctly. I cleaned everything real good and set the flame guide in place and it still wasn't sitting on the burn pot right. Then I took a long screwdriver and pushed the Flame Guide down toward the back and its been fine ever since.
  25. Luv2burnPellets
    Luv2burnPellets
    Member 2.
    NULL
    Jan 21, 2014
    189
    49
    Loc:
    Central Maine
    My stove dealer told me that these flame guide plates definitely have a life span, and the life span is done when they either crack or warp after years of being subjected to high heat. All depends on how many tons have been burned, and how hot it has been, but they do not last forever.
Thread Status:
