Just recently I noticed our Harman XXV was burning with a very low flame and little heat. Thought initially the temp setting was turned way down but it was still set to 4 in stove temp mode. The hopper had plenty of pellets so that wasn't the issue either. I shut the stove down and gave it a good cleaning. After relighting, the problem persists.
It appears that the auger will feed just enough pellets to feed a small flame, then no feeding for about 4 minutes at which point the flame is almost out. I through a handful of pellets into the burn pot to see how the stove would burn with more fuel and there was a nice tall flickering flame like normal until it died down again. Ran the stove overnight to see if the problem would correct itself and no luck. Glass and heat exchanger turned a sooty orange color (normally always a powdery white) and not much heat.
Just wondering if anyone with an XXV or other model Harman has experienced this problem and what the solution was. The stove is less than a year old and I'm pretty meticulous about keeping it clean. We burned almost 5 tons this winter and I cleaned the stove following the manual after each burned ton. The only thing I haven't cleaned yet was the main flue which I was going to do at the end of the heating season. Could a dirty flue cause the problem I described? Or, maybe the ESP probe is acting up? Thanks in advance.
