Has anyone installed a damper in a flex liner?
woodmiser
390
Garnet Valley, PA
I think it's doable. I'm thinking of installing a cast iron key damper plate inside my Clydesdale's liner just above the exit. Fabricate some type of lever mechanism so I can operate it from the front.
I think it will be easier to just drill the holes right in the liner instead of trying to find and install a damper unit that fits the stove outlet and accepts the liner.
I wouldn't do it. A flexible liner is thin stuff not designed to have holes drilled in it for a damper.
Also, unless you have an overdraft condition due to a very windy location or an extra tall chimney, you really shouldn't need a damper as they won't increase the effeciency of a modern stove. If used when not necesssary, they will actually decrease efficiency.
What is your concern leading you to believe you need one?
pen
Often I can't get the fire down to prevent runaway. Everything has been checked as far as leaks are concerned. My draft is high. My wood is dry. I need more control. EPA doesn't allow manufacturers to let you shut it down if required.
Is this on a reload or bringing it up from a cold stove?
Either one. If I load it up tight from a cold start or after a reload. Obviously a reload situation is worse. I can usually keep it in check but not without keeping a good watch. When it does run I have to open the door and or throw in a green ugly.
I'm not familiar with the Clydesdale, but is there any way to partially restrict the air intact?
I hear you but I don't think it will be a problem in the liner. But before, if I even do it, I have a left over piece of the liner I'll do an experiment on.
While the corrugations are tough, the material inbetween isn't when it comes to tearing. I'd be worried about making a point where the liner can rip.
pen
I already have the liner appliance connector screwed onto the end of the liner. If I used a damper assembly like you mention BB, will the adapter fit into the top of the damper assy like it goes into the stove? That way all I have to do is take out the three screws holding the adapter/liner to the stove, pull the liner up, install the damper assy and drop the liner back into the damper assy.
