I have a 2016 f150 5.5 foot bed. Load capacity is 1,748 pounds. Question is would you load a ton of pellets in this truck? The pellet store is a mile from my house.
Could be hard on the tires too. Check yur load rating on the tires ,could do damage that wont show up right away. No way would i intentionally overload a new truck.
2X what adayrider said. I've got a 2013 1/2 ton Silverado 1500 crew cab, 4 wheel drive. It's rated for 1950 lbs payload. So far it's moved 11 tons of pellets in 2 years with no problem. Fill your tires up and watch your starts, stops and turning. As with any loaded vehicle, the dynamics change with more weight. You shouldn't have a problem. Especially with the short distance your going. Just make sure it's pushed up against the front of the bed. I also remove my tailgate. Helps the towmotor in loading and removes some rear most weight. Just strap it down. I also moved 6 ton of pellets with a Dodge Dakota V-8, extended cab 2 wheel drive. Yes it was over loaded, but driven sensibly and a short distance, it was fine. And 2 years later, it's still fine.I used to haul 6-7 tons of corn a year. 1 to 1.3 ton at a time from 6 miles away with no problem. This was with a 1996 f150 and the newer trucks are so much better. It will definitely squat it to the max. It will be a low rider on the way home. Just don't go 100 mph and leave plenty stopping distance and you will be just fine. Preferably not on wet roads but I have done that to. When they load them have them load them as fas forward as possible. If you can get them all the way to the front it will put some of the weight on the front wheels and all the better. I have hauled a skid of water softener salt 1.2 ton 35 miles come to think of it. 1 mile is nothing. It just takes common sense, but some say I have none of that LOL I'm sure you will get get mix answers on this so you will have to make the decision.
If you have an extra cab with a back seat throw 15 bags in the back and the rest in the bed.
Thanks for advice everyone.
Yes. I had already planned on doing it just wanted some reassurance. My old truck was a f 250. I have hauled 1 ton pallets probably 30 times with that truck. Im not real concerned with this truck. Will add some air to the tires prior.So what's that mean?
Are you going to try it?
