Hearth Gates for Children Recommendations?
isipwater
371
Southeastn, AZ
I've sold & installed the Kidco Gate. I haven't seen the others, so I can't compare them. Kidco is nice because you can add or subtract panels if you need to & they come with the wall mounting brackets so they can't be pulled over. The latching release mechanism is designed so that small hands aren't able to open the gate portion. You can adjust the angles between adjacent panels as needed. Comes in white or black, & seem to be well made. HTH
Reactions: isipwater
Intalled the Kidco last week. got it because it was the only one that would clear the stone hearth and had fairly solid anchoring system. After installing it i like it alot. as Daksy said it is anchored to the wall (wood screws) and adjustable for angle to make it as space efficient and as pleasing to eye as a giant fence in your livingroom can be. The gate is such that i have to think and work at to get open and takes a bit of strength.
