Hello everyone,
I FINALLY started my fireplace project, and just finished framing out the hearth with 6" 16 and 18 gauge steel tracks/studs. It will go over a slab of concrete which I poured the other day after building a wooden form against the chimney.
The buildup of the hearth starting bottom up will be this: concrete, single layer of 1/2" Durock cement board, steel stud framing, 3 or 4 layers of Durock (thinset together and screwed down to the steel frame with no matching seams), then slab of 1.5" thick bluestone (7' x 20" about 250lbs).
Do you think it is ok to put that much weight on three layers of Durock? I just want to make sure they will hold their shape and will not shift over time.
The reason for the 3-4 layers of Durock is for more R-value, but mainly to build it up so the bluestone will match the height of the firebox.
Thanks for any guidance you can provide!
