Hearthstone Build Quality?
lumbering on Posted By lumbering on, May 11, 2013 at 8:04 PM
  1. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,361
    2,096
    Loc:
    Cascade Foothills, WA
    Looking much better. Nice to have no R requirement for the hearth too. Good moves.
  2. Woody Stover
    Woody Stover
    Minister of Fire 2.
    NULL
    Dec 25, 2010
    8,256
    2,334
    Loc:
    Southern IN
    They've got a brown one in a shop here; That is one sweet-lookin' piece. :cool:
    I noticed a bit of slop in the hinges on SIL's Fireview, probably fifteen years old. Also looked like it had a hinge pin that wasn't OEM. I put a bigger pin in and that helped. I think I'll rub some pencil lead on my Woodstock hinges from time to time...
  3. Backwoods Savage
    Backwoods Savage
    Minister of Fire 2.
    NULL
    Feb 14, 2007
    27,815
    7,368
    Loc:
    Michigan
    If my memory is correct, that last time we looked at new stoves, Hearthstone was the first one we looked at. The do have some beautiful stoves.
  4. ddddddden
    ddddddden
    Minister of Fire 2.
    NULL
    Oct 20, 2009
    1,365
    180
    Loc:
    Central Va
    Yeah, it looks like they went with an industrial-strength latch for the beautiful new Manchester. Hopefully, this is a good design that will trickle into the other stoves.
    http://www.hearth.com/talk/threads/hearthstone-manchester.108690/
    HS vs. WS. . .clearly I am biased, but I have a few impressions to share, FWIW. It be that there are simply more HS stoves out there, but it seems like more of the reports of cracked stones involve HS than WS, and the WS designs seem to be more fail-safe. HS uses single 1.5"-thick stones. WS uses double-wall 1.0" + 0.75" stone on the older models. The PH uses a steel firebox with stone attached inside and out, so any cracks in the stone would have no effect on function, AFAIK.
    Also, it seems like a few HS owners have issues with losing heat up the flue, so they run a flue damper. . .it may just be coincidence that several HS owners have tall chimneys and need a damper, but this does seem to me to be more common with HS installs.
  5. Dairyman
    Dairyman
    Minister of Fire 2.
    NULL
    Nov 15, 2011
    617
    303
    Loc:
    Southwest MO
    This is my only problem with my Mansfield running on a 15 ft chimney. But I still love her even with duck feet.
  6. Highbeam
    Highbeam
    Minister of Fire 2.
    NULL
    Dec 28, 2006
    12,361
    2,096
    Loc:
    My heritage dumped copious amounts of heat up the flue. Air shut off cruise for overnight burn would easily be at 800 internal flue temps. Frequently ran the flue temps up past 1000. Pretty ridiculous. That said, the dang thing performed per the specs so I blame most of that flue heat on the non-cat design in general.
