My husband and I got our first wood stove - Hearthstone Heritage for our new addition to our cape installed a few weeks ago - yahhh! Knowing nothing about wood stoves, I first read the manual and then moved on to better things... I stumbled on this site and LOVE IT! I've read a ton of posts on this site to answer my initial questions. So far I've learned some of the terms, common running temps, types of wood to burn, what the heck secondaries were, burning N/S or E/W (this I had to google to figure out what the heck that meant) and thermometers and where to read from...
But trying to tie everything together for my particular stove is tough... so I had some questions I felt I wanted to see if someone can answer for the Heritage.
SO! Onto my questions... and excuse me if I use the wrong term..
Trying to gauge the temperature of our fires (we don't have a thermometer and have a double wall pipe) I borrowed a friend's IR gun and took some readings after we got a good fire going (confirmed secondaries were going)- warmed the lower level up to 76... and took some readings. If my reading on the center stone of the Heritage is about 375 - max <400.. is that the temperature I should be using to judge the "running temp" of the stove? Like is that what I'm basing it on when I would say something like "Yeah, got my stove to xx degrees"... ??? I noticed that if I took temps on the right side bottom stone - it could be 100 or so degrees higher....
But what I'm not sure of is - with all the discussions about differences in the temperatures and where they get them from - mag thermometers (which I think I can't use due to the double wall pipe) and the fact that my husband doesn't like the idea of drilling into his pipe to put a pipe thermometer in - when someone says they are burning an xxx degree fires with the heritage/any soapstone - where are they getting the temperature from?
2nd question - Not being used to wood stoves -I'm terrified of overfiring - obviously you read the manual - you read the posts about it - BUT for my stove - how would I overfire? What would I have to do to overfire? Keep the door open and the damper all the open? Even when I fill the firebox up - get that going with the door open for 10 minutes or so and the damper open - the IR gun temperature doesn't go much into the 400's????
So what is the best place to take a temp reading - is a thermometer placed on the center stone good - if my husband doesn't want to drill a hole - and IF we do put a pipe thermometer in - from what I've read - it sounds like that temp is going to be different than the one taken from the stone top?
Is a temp of between 380/420 from an IR gun on that stone - a good temp - without fear of running a medium-small fire that creates creosote????
Arghghhggh - so many questions!
If anyone can answer just one - I'd be a happy girl!
Thanks,
Karen in CT
Thanks,
Karen in CT
