To all. I recently installed a used 3 year old Hearthstone Heritage stove I picked up late last winter. I had planned to redo the hearth since my wife doesn't like the color of the hearth with the soapstone but now the time has come to start burning. I finally said screw it and removed the old 1985 Jotul 8 and installed the Heritage. Figure to just burn the stove this season as is to see if it does a better job.
Anyway, on Sunday evening I started a fire to see how it burns and to show my wife how to operate it if I'm not here and she wants some heat. I installed a flue gas thermometer in the dual wall stove pipe and have a surface thermometer. So after getting a good fire going with 4 logs I could get the flue gas temp up to 600F, not sure if that is a good temp or not. I had the surface thermometer on the collar which I don't think is a good spot for it. Where is the best spot for the surface thermometer and is there a target surface temp I should shoot for? Also, is it a good idea to keep the ash pan full never cleaned out and scoop ash from the top, which is how the previous owner ran it, or clean it every few days? Is it also a bad idea to open the ash pan door to get a fire going instead of cracking the side or front door open.
Thanks in advance.
Thanks in advance.
