    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Mainely Saws Member
    Topsham , Me.
    Hello folks ,
    I saw this stove for sale on Craigslist for $800 without any venting pipe & was wondering if anyone has any info on this stove ? Likes , dislikes ? Is the price reasonable ? Is it a dependable heater ? Etc , etc ,
    Thanks ,
    Bob
    #1
    Helpful Sponsor Ads!
  2. Wood Heat Stoves Minister of Fire
    Nevada City, California
    great stoves, which model of Tucson?
    they have b-vent, direct vent and vent free.
    plus different burner versions of each
    manuals for current models at hearthstonestoves.com, if you need the book for older versions, let me know :)
    with a retail around $2000 new, 800 isn't bad if in good shape. but, the older burner isn't nearly as realistic as the newer ones...
    edit, yay! a new thread in it's a gas
  3. Mainely Saws Member
    Topsham , Me.
    The ad says it's a direct vent but the pipe is not included . I'm not sure if a wall thermostat goes with it . Thought I'd wait to get some info before I called ...
    thanks
  4. Wood Heat Stoves Minister of Fire
    needs 2-3 feet of vertical to work well on lpg if memory serves me...
    i sold a lot of those units, they have been very reliable. uses std Nova sit valve and pilot assy
    any milivolt t-stat will work
    looks like the 8700 model btw, if you need the manual, email me direct
    daveg@woodheatstoves.com
  5. Mainely Saws Member
    Topsham , Me.
    Thanks Dave , I'll be sure to let you know if I need the manual . So if I have 7 1/2 ft. of ceiling height & I run the pipe vertically say for about 4 ft . above the stove then I wouldn't need any kind of further piping running higher up the outside wall ?
  6. Wood Heat Stoves Minister of Fire
  7. Fsappo New Member
    Central NY
    Thats a fine stove your looking at for a great price. We have tons of them in the field. When we do a "standard" install we go up 24" 90 degree, thru the wall with a thimble. Remember to get a vinyl siding kit depending on your siding. If the stove doesnt come with a thermostat, no biggie. Just grab one from the hardware store for $30 or so. You can expect to spend about $375-$450 on venting. You should be able to buy that and the thermostat at your local hearth shop. Would be good to introduce yourself to them anyhow in the event you need help with the stove
Thread Status:
