Q&A Heat Chamber on Woodstoves
QandA
Staff member
Nov 27, 2012
0
Question:
I am in the process of selecting a pellet stove to replace an aging coal burning insert. One dealer I went to swears that bottom feed mechanisms are the way to go- while another says that only the top feed are acceptable. Actually- the latter brought up a good point... he said that bottom feed stoves are more prone to back-fires. Can you shed any light on this subject?
Answer:
Back feed can happen with either type. Here's the basic scoop"
1. Top Feed ... More efficient by a few percent or more...can usually turn down lower...needs the best quality of pellets...fire goes out quickly if everything is not just so since the firepot only have a small amount burning in it...fire is not as realistic as bottom feed.
2. Bottom Feed....Can burn any quality pellets- some even burn corn....Have a large ember bed- so do not go out easily..have a much better looking fire....may be less efficient (depends on brand and design.Harman stoves has a good reputation for bottom feed stoves...Travis industries (Lopi and Avalon) for top feed..but there are many others worth considering also
