Help make a leak proof connection
wolinski
12
ny
I will br running the flex pipe down the chimney this saturday.
My set up is stove will sit on hearth in front of fireplace, flex pipe will connect to a T , then connect to stove.
The stove is a Homstead.
My question is the T connector has a pipe that connect to it to form the T, it looks like you tighten a clamp to make the connection. When i dry fitted it , it looked like the connection isnt air tight. What would i put on the joints to make it air tight. Or when I do it , will it become a tight joint. not sure if that makes sense
It sounds like a removable snout T. You could gob the snout up with furnace cement before you slide it in and crank down the band clamp. Otherwise if you crank the clamp down really good any small gaps will soon get plugged up with creosote most likely.
