Help! Pellet stove not feeding pellets. No power going to auger motor. Quadrafire Santa Fe
Airstang93
8
Ohio
Hello,
Im at a loss, i have a quadra fire santa fe pellet stove insert. original owners had it installed in 2010, we bought the house in 2014 and used the stove during the winter with no issues. Last year, 2015, I attempted to start the stove for the winter and it did not feed pellets, i left it sit all winter. This fall i started messing with it, ive changed all 3 snap discs, igniter, thermocouplar, vacuum switch and had the chimney swept out. Im still not getting the stove to feed pellets. I pulled the auger out and made sure there was no blockage. I also jumped the motor and found it still spins. The convection and exhaust blower both work and i get a fire if i load the burn pot with pellets. The chimney sweepers put a volt meterto the auger motor and he told me it was getting no power to the motor. Any ideas where to go from here?
Thanks
Is the combustion blower motor turning and getting power? If it is, as a temporary test, jumper the vacuum switch and try. Unplug the stove before working inside, of course.
Reactions: kappel15
Yes, combustion turns on as soon as i plug it in. I used a 5amp fuse last night and jumped the vacuum switch, nothing changed.
For the bad news ... sounds like a board issue. If the combustion blower comes on as soon as you plug it in , that is likely what it is. Some stoves do this automatically, shutting down after it determines there is not heat ... the Elena does. Don't think quadrafires do but have been wrong before! Will poke around the manual a bit.
Have you had it on a surge protector? If not get one for the new control.
Not on a surge protector. We dont keep it plugged in unless we are using it and like i said, it worked fine in 2014, unplugged it for the summer, then plugged in for 2015 and no feeding. Unsure if the power ever went out whike we used it in 2014, dont believe it did. I was thinking board since ive replaced everything just wanted to see if anyone had any other suggestions before dropping 200 bucks.
Connection wire to the auger. Can you test voltage at the controller ? Just had someone report same problem (Whitfield), grandpa checked the wires and one was bad, he replaced the wire and all was well.
Is there a hidden switch to the auger, pellet fuel cover or door switch ?
Just had someone find a bad wire going to the auger motor (Whitfield) from the controller, used ohm tester to check each wire. Replaced it and now working fine.
Is there a switch bad on the front or feed door ?
#2 snap disc may be defective.
I replaced snap disc 2. when you say controller are you talking about the control board? i have not tested them, suppose that is worth a shot. no switches from what i see on the feed door
I can't remember what year, when they started putting switches on the hopper door. If door is open, it shuts power off to the auger motor. It could also jsut be out of adjustment . Do you know any one that has a Quad stove you could test your control box in,before you spend the big bucks? And always unplug stove before removing or installing a control box. You can try unplugging stove and makin sure the control box is seated properly. Sometimes they can vibrate loose just enough to cause issues. kap
Reactions: Former Farmer
Double check the thermocouple ... from the manual: IMPORTANT DETAIL: The tip of the thermocouple must be in contact with the inside end of the thermocouple cover.
Reactions: kappel15
Did you remove the control board, clean the contacts and reinstall? Always unplug the unit before working with the control board.
I see KAP beat me to it.
If stove is on(remember initial feed is only for 60 seconds) check power at vac switch. If no power from red wire-- check control box or wire harness.
check for power at the orange wire on the #2 snap disc. If power is present, could be feed motor or capacitor. If capacitor, you can fix cheaply with a capacitor jumper. Otherwise,you now have to buy a new auger motor, to get capacitor. kap
If you can't find anyone with a stove to put your control box in, or a dealer that can test it, you can send it to me, and I will test it in my stove. kap
The exhaust fans do come on right away when you plug them in. Also first thing to come on when you call for heat on tstat.
Reactions: Lake Girl
Hard to say as I don't get all around the country. Well, maybe on here.:) If I had to percentage, maybe 30 % or more. They do wear out. kap
According to a schismatic I found, there is a hopper mini switch.
Unfortunately, no, I don't know anyone with another stove. I did pull the board off and reseat it,nothing. I don't see any switches and I don't see anything about it in the manual. I'm going to pick up an ohm reader and try each wire and go from there.
Reactions: kappel15
There's already a jumper on my auger motor, is that not originally like that?
Isn't the capacitor on the auger replaceable ? If you can read the capacitor, any electric store should be able to replace it.
.68 micro fared, 275v gotta be a $2 capacitor. synchronous motor capacitor, the capacitor is needed to start the motor, but if no power is going to the motor, something bad.
Older stoves don't have a hopper switch. Can't remember what year they started putting it on all of em. kap
