help with adding thermodisc to blower
devinsdad
227
northern NY
I would like to add a thermodisc to my blower but the one available is for an Avalon.Would like to know how or can I make this work before I buy it?
Thanks for the info.Any idea what to do if my blower doesn't have the quick connect wires?
I haven't had a chance to look at how my blower is wired up but my hunch is the thermodisc simply acts as a thermal relay to turn on/off blower via other electronics within the variable speed control unit. The power to drive motor does not pass through the quick connect wires/thermodisc since gauge of wire is far different between the two.
Can you provide any info about the blower you do have? Does it have a part number? Is it variable speed?
Most often on woodstoves the thermodisc is rated to switch the amperage of the blower and is direct wired in series with the low-amperage blower. If you are not electrically inclined, maybe keep it simple using a Stove-Stat?
http://www.northlineexpress.com/itemdesc.asp?ic=5SA-9600
I wasn't sure on mine... that is probably how mine is as well.
Good recommendation... that unit should easily do the job.
That stove stat looks like its around my electrician abilities :) Thanks for the info
