I seem to have a hit a bit of a snag on my outside air kit install. I have an exterior chimney that I am trying to drill through to run a 4" OAK for my wood burning insert. I have cut away the 1/4" steel plate of the old firebox, and the 1/16" steel sheet metal covering the brick. From my measuring, the brick is nearly 28" thick on the side I want to cut to run the duct. I was to go out the side of the chimney, but I don't think that going through the back is going to be any easier.
I have a hammer drill and an 3/8" diameter 18" long masonry bit that I was going to use as a pilot hole to see where it came into the firebox at. I was hoping I had measured wrong and the chimney was not really 28" thick. The bit bottomed out without breaking through. My plan was to drill a circular pattern of holes and then just break the brick out around it as I went deeper.
I have called around to all of the tool rental places and no one has a core drill that will go that deep, or even a 36" masonry bit I can rent. I have found 36" long bit on the internet, but was trying to avoid having to purchase one for just use. I can also purchase one at my local Grainger's for nearly twice the price as online.
I am looking for any other options or opinions.
