Hello, I am new to the site but have been burning wood for over 30 years. I've had a couple of chimney fires, luckly with no fire into the house. I'm using a Jensen insert in a clay tile lined masonry fireplace of a 1963 home. It is a ranch home with a 15' tall exposed chimney with 11 1/2" X 11 1/4" I.D. clay tile. My Jensen has a rectangle exhaust opening of 14" X 3 3/4"(53 sq in). My tinner friend made a transition duct to 6"round(28 sq in) out of 1/8 steel. I removed my damper flap/door from the fireplace. I have search the forum for information, but still have these questions. Since I like my old Jensen (made here in Racine WI) can I neck it down to 6" and still get good results/draft? Do I need to insulate the SS liner? The 6" liner would fit through the remaining damper assembly easier than a 8" liner, or do I cut out the remaining damper assembly? I see some oval SS liners that would fit easier through the damper assembly, but how is it transitioned back to round? I would like to do this project myself. A contractor advised he would only use 8" uninsulated SS liner and remove the existing damper assembly for $1600.00. Any comments would be apprecieted as I know I've been living on the edge with my current set-up. I understand how and why the creosote build up is so great in my Slam in insert. I'm not going to use the insert until I line the chimney, and my girls are already complaining it is too cold in the family room, and too hot in the bedrooms.
Thank you, kurly
Thank you, kurly
