High Tempertaure Silicone for door gasket
Brian26
694
Branford, CT
I ordered a gasket kit for my Drolet 1800 insert last year from SBI. It comes with a tube of high temperature silicone and just got around to doing it.
Went to replace it and found the sealant tube solidified. I should have done it last year and understand it probably hardened after sitting for a year plus. A new gasket kit costs around $30 and I have the gasket just need the silicone.
The tube is NuFlex 302 high temp silicone. A google search didn't turn up much.
Is there something else I can use? Maybe available at lowes or home depot as I want to get this project down this weekend?
Any stove shops or industrial supply places around you? May be able to get a tube there... Not sure how the ones available at lowes or HD compare....
Edit: Check automotive shops for the nuflex ... mentions engine gasket making...
Stove gasket cement. Rutland is one brand, there are others. Big box or a decent hardware store should have it.
Lowes and Home depot should both have comparable high temp silicone.
Strange it was hard in the sealed tube. But it must have a shelf life. Ovecourse you can you any of the gasket cements you find at stove stores.
I liked the high temp silicon. I found it to adhered to the gasket and door, and remained pliable. I got it at a automotive parts store. Ultra high temp copper.
