Homelite Chainsaw idle issues
bayshorecs Posted By bayshorecs, Oct 7, 2008 at 3:43 PM
Thread Status:
  1. bayshorecs
    bayshorecs
    New Member 2.
    NULL
    Sep 28, 2008
    214
    0
    Loc:
    Central Illinois
    I have a cheapo homelite bandit chainsaw that is giving me some headache.
    The saw refuses to idle without reving the engine. If I set it down, the saw will die. Other than that, it cuts fine. I see a couple of adjustment screws on the side but I don't have a manual to know how to adjust them. There is a 'T', 'L', 'H' adjustment. Which way and which one should I mess with?
  2. gary
    gary
    New Member 2.
    NULL
    Oct 29, 2006
    70
    0
    Loc:
    St. George, KS
    Had/Have the same problem with a Homelite. I was thinking it may be the air filter but when I opened it up, couldn't even find the air filter. Took it to the saw shop. They said all they did was clean the carb. Runs a little better now but still not right. Hopefully, somebody more knowledgable about Homelites can help us out.
  3. aandabooks
    aandabooks
    New Member 2.
    NULL
    May 29, 2008
    141
    0
    Loc:
    Central Illinois
    The "T" is throttle adjustment, the "L" is low side gas input to carb and the "H" is the high side. The "T" should be adjustable with a small flathead screwdriver. The L & H will either have limiters or need a special tool to adjust. Try turning the "T" in CW. This should give the saw more throttle while at idle. You don't want to go so far as to have the chain moving while at idle.
  4. kevin j
    kevin j
    Minister of Fire 2.
    NULL
    Jan 21, 2008
    607
    48
    Loc:
    minnesota us
Thread Status:
