    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
  1. higginscl New Member
    Iowa
    I am installing a wood furnace and need to re-line my chimney with a SS flexible liner but my problem is the old brick chimney is knocked down below the roof line. All the liner kits I have found dont have a way to transition to class A double wall to pop out through the roof. Am i missing something or is this impossible? Maybe i need to look into doing something different. Any suggestions would be great.
    #1
    Helpful Sponsor Ads!
  2. DAKSY Super Moderator
    You need a Chimney Liner-to-Class A adapter plate. It gets mounted to your masonry. Use the search function & you should be able to locate some discussions on the subject.
  3. higginscl New Member
    Iowa
    thank you ill check it out.
  4. mellow Minister of Fire
    Salisbury, MD
