How do I remove the IFC in my Grundfos 15-58 pump?
They pull out with a pair of pliers. The ones I use are just a white plastic flow check in the outlet side of the pump. If yours is like that put a pair of needle nose on one of the 4 ears and pull it should come out its a o-ring seal.
That's right. Be sure to make a note of which way it goes in there, just in case you ever want to put it back.
Woodnotoil- am I remembering that you're aiming to plumb two pumps in line, aiming "at each other" so as to be able to flow either way? It is a concept I may end up wanting to try, too, but are you sure you won't get whopping head loss doing it that way?
Trevor - I emailed Taco and they said there is very little head loss going through a pump. We figured out there is more loss when using zone valves. So not only is it less expensive (not having to use zone valves) but there is less head loss. I am using a DPDT relay (at nofossil's guidance) to ensure both pumps don't run at the same time.
woodnotoil- so they (Taco) confirmed that even when you're working one pump through another in series in reverse? I don't want to sound like a 'nudge- just am very, very interested in the potential approach, as it may work well for me, and I don't want to duplicate your "due diligence" if you have already done it
Trevor - Yes, even in reverse. They said it simply acts as an extension of the pipe and therefore does not increase head loss. Mine should be up and running soon. I will let you know how it works. I am happy to be a guinea pig on this one.
