How to accurately take stoves heat output
chrisasst
1,289
cortland ny
Ok, I have searched and no such topics as I can see. How do you all take the temp of the heat that is blowing out of your stove. I have a meat thermometer stuck in a blower tube which is not very accurate, and I can hold my hand steady enough to hold it in from of the blower to get and accurate reading. I know I saw some pics before of some of yours but I can find them...
My wife's way. Stand in front of stove about 18 inches away. Turn 180º and stick out your back side. With in a minute she knows what pellet is in the hopper. No fancy tools either. She will point to the stack. I just don't know how she does it! :)
My way and I wouldn't call it proper. I just measure the air temp, Not the stove temp. But I really feel that as long as you do it exactly the same for each brand. It shouldn't matter much. Those cheap magnetic flue temp thermo's work good enough. The IR guns are picky about surface temps. Shiny surface is tougher. if all you have is an IR try for a flat black area.
