    Jotul Cast Iron Stoves
    Woodstock Soapstone Stoves
Thread Status:
  1. Nickolai Member
    Western Ontario
    Yeah I realize this must be a stupid question, but my pellet stove came with a black coil handle that is supposed to go onto the actual door handle.
    I've tried to just twist it on and to force it on, both to no avail. Is there a technique other than brute force and ignorance....????
    #1
    Helpful Sponsor Ads!
  2. jtp10181 Minister of Fire
    Madison, WI
    Push as hard as you can and screw it on in the direction of the spiral. If you need to use some lubricant like a little glass cleaner or some Crisco or something. Once you get it going only screw it enough so the handle starts coming through the tight part of the spring. Some people keep going and put it down way to far and then its damned near impossible to get back off again.
  3. Nickolai Member
    Western Ontario
    Thanks, I might try some kind of lube. I'm not getting anywhere and have been fighting with it for awhile now.
  4. Nickolai Member
    Western Ontario
    Got it! Used some cooking spray in place of Crisco and pushed as hard as I possible could. Something that would have been made a lot easier with a vice to hold it straight while pushing it in.
  5. hearthtools Super Moderator
    The last one i fought with 10 years ago
    I filed down the end of the shaft to taper it.
  6. CygnusX1 Feeling the Heat
    Central MA
    Try some dishwashing detergent, it sounds funny, but it will help the handle slide on
Thread Status:
